Brentwood Bob
The huckster has a plugged radiator. Isolating it I got 3/4 gallon of rusty water out of it along with a black residue. When I drained the system at the petcock I got clean looking antifreeze.
So I'm going to pull the radiator and get it rodded out.
Also, I will back flush the block, and probably rig up a bubbler to let some dish washer soap work on the scale in the block.
Judging from the rusty front spring, and front cross member the radiator has had a problem for some time. The owner asked if I had drive the truck much since the repairs were done. When I mentioned the water problem the use of the water came to light.That's the reason for the new radiator and leakless waterpump. The whole system needs to be clean before running a new radiator.
Any ideas or suggestions are welcome.
