Loose fuel pump eccentric
Unshined2
Did a search and I couldnt find any answers, so Ill have to ask here on the board.
I changed the timing chain on my 59 292. I installed the gear, fuel pump eccentric, spacer, washer and cam gear screw. And the fuel pump eccentric is still loose. There is a .045 gap with screw bottomed out on the cam. What am I not seeing? Are there different cam gears from early to late style yblocks? There wasnt a counterweight installed on old timing set.....Thx
This should help.
Oldmics
Hopefully that rear thrust washer is stuck on the backside of my timing gear. The 59 Ford Shop Manual doesnt show a nice assembly pic like the one you showed....
Oldmics ...???
What year(s) SHOP MANUAL(S) did you source those Illustrations from?
The answer is
