Lockwood outside brakes
Does anyone know anything about accessory Lockwood brakes (small drum) ?? Are they activated by separate rods from a separate handle, hooked up to the existing emergency lever, or connected somehow to the brake pedal?? I'm in the process of buying a '25 coupe that mayl need some extra help getting stopped .Thanks :Bruce
http://www.mtfca.com/discus/messages/179374/246936.html?1321237805
http://modelt.org/discus/messages/2/27217.html?1291321249
http://www.mtfca.com/discus/messages/179374/204715.html?1315216050
http://www.mtfca.com/discus/messages/331880/402037.html?1384711491
These should get you started. If they are cable activated there is a lot of info on hooking them up. If they are rod, I would use the unit shown in the last link. It hangs on the cross shaft but swings under so you still have your parking brakes which the equalizer sold in the catalogs does not.
MarkG
