hi rich, how much will it cost shipped? i think it will go in a small flat rate box, which is about $5. i need it for my 31 PU. the tank baffle mbove the column is loose and causes a very irrirating vibration at certain speeds. someone on here suggested the newer bracket, and then put some rubber between present bracket and column to force bottom of tank upwards and stop the noise. kind of half baked but i think it will work. hope all is well over there. TV says you guys are pretty warm. been pleasant here, a bit on the coolish side. take it easy, roger
