It is a hot air fitting for the choke. It connects to the choke fitting marked with an arrow in the first picture below.... and yes I know my hot air choke isn't connected. I don't know where to connect it to at this point in time. I don't think the part my post is about would be a hot air source since it is in the intake manifold, but I could be wrong. So, what is that thing in my intake manifold for? Just a manifold vacuum port? Thanks for all the inputs.
The parts of a repair kit are shown in the second photo.
Thank You..I do have that round button on the opposite side, and that was going to be my next question..Pictures are great
You've got a couple of problems there. You have the 4-bbl teapot and you are using it with a 2-bbl distributor. The proper distributor for use with that carb has a dual vacuum advance which I believe should be connected to that open port in the carb right above where the vacuum port is on the manifold.
Thanks..I do have a mish mash going on. That vacuum port was home of a mud dobber, and nothing connected to it. I am going to experiment with the loadomatic and see what happens. Thanks
Look at your choke housing and you can easily see at the bottom on the left hand side of the choke is the port on the carb for the heat riser tube which is missing altogether. There should be a copper tube with a fabric covering running from the choke heat riser port to the manifold heat riser passage.
Yes, I was wondering where to hook the hot air choke to, but looks like I just found out. Thanks.
It's the hot air source for the auto choke, which you don't even have hooked up.
Thanks..I stand corrected..I thought the hot air would come from the exhaust manifold somewhere. Wrong again..I am still in the process of getting the engine up and running on its own..Thanks again..
LOOK AT THE PICTURES that dmsfrr sent you. Again, LOOK AT THEM. you will see that the curly one is swedged on one end. It will slide into the fitting you have blocked with a screw. There is no need to block this thing. There is nothing going thru it until you connect it to the carb. The carb then supplies the necessary vacuum to pull the air thru it. The possible reason it is plugged is the straight tube runs thru the intake to the left side, where it is connected to the little round "filter", is rusted/burned thru, which is a common thing. If it is rusted thru, exhaust will come out of the tube with the screw removed. You will have to pull the intake, and remove the tube, and tap in a new one, then reassemble the whole thing and viola, the whole thing will make sense. This isn't rocket science, in fact, it is not even hard, it just takes a little time.
Those tubes going across in the intake rot out, may be why it is plugged with a bolt. If the tube rots out it will have a exhaust leak at the port. If the tube is good there is no need to plug that port.
I think the hot air tube thru the exhaust crossover was discontinued after '57 due to the burn-thru problems.Those tubes going across in the intake rot out, may be why it is plugged with a bolt. If the tube rots out it will have a exhaust leak at the port. If the tube is good there is no need to plug that port.
Ford may have had the choke hot air fitting for most(?) '56 / '57+ full-sized cars and trucks on the right side exhaust manifold. photo 2...I thought the hot air would come from the exhaust manifold somewhere. ...
The 56 Birds had fittings on both ends of the tube that ran through the intake. One was connected to the choke and the other, through a metal tube, run into the carb air horn. No round thing on the drivers side. Is the sedan different?
55's had the choke mounted on the intake. It looks like the poster has a 56 setup, unless the 55 sedan were different than the Birds
