oldford: the clips go on the inside of the yolk, they are to prevent the bearings from being pushed out due to side-to-side movement of the cross. After proper installation the cross will feel tight initially, that's normal. Go to
this link (Bob Drake Reproductions) and hover over the picture to see it expanded.
Just a thought: you are installing these in a Lincoln-type U-joint rather than the original with the two halves riveted together, aren't you? Maybe you could put up a picture of the U-joint you're trying to rebuild so we could better see what your issue is.[/QUOT
This is a model a joint like the one bob drake shows (which is what I should of purchase instead of a kit). I know the purpose of the clips and where they will be once installed. I just do not know how to assemble. It looks to me like the clips are not made right. I should be able to install the clips and cross, which I have and tap the bushing in place with the chamfer of the bushing on the inside thus pushing the clips in the slot of the flange. I know there should be resistance when I try to push the bushing in but the edges on the end of the clip will not let me. They stick out to far. Not able to take pictures, thanks
No, you install the clips
after you have installed the bearings and cross into the yolks. You partially install one bearing, put the yolk into place, then install the opposite bearing capturing that arm of the yolk. I use a vise to squeeze the bearings into the opposite sides of the yolk. Be careful, it's not difficult to get things wedged so that you are pushing against the ends of the needles in the bearings rather than having the arm of the yolk within both bearings.
If you already have the bearings and cross into the yolks but the grooves in the bushings are still covered by the yolk, you'll need to use a socket or something one one side to gently push one bearing in a bit farther to expose the groove on the inside of the yolk arm. Install the clip into the groove, you can use pliers, your vise or whatever works for you. Afterwards, use that socket on the opposite side of the yolk to push that bearing in, that will force the other side back so that the clip is pushed against the inside of the yolk, where it belongs. Install the second clip then use a large screwdriver wedged against the cross to gently prise the bearing you just installed outwards so that the second clip is pushed against the inside of its arm of the yolk. That gives you the proper side-to-side clearance without causing the cross to bind.
Repeat for the other yolk.
BTW, I got a Bob Drake repo U-joint that had a washer stuck between one yolk and the cross, which made it so the cross would not turn. I had to disassemble it to remove that washer before I got it to function properly. And no, this wasn't the thick washer that goes under the bolt to the back of the ******, this appeared to be something that got in there mistakenly during assembly. That having been said, as near as I can tell the Bob Drake repos are the best ones out there.
