I torque mine to 50lbs. while the engine is cold then once again when the engine is warmed up.
So you got your new manifold, are you going to be running a Weber dowmdraft then instead of the tow motor carb? Let us know how it works out....
I just put mine on yesterday before reading this post using my normal method of a 3/8 ratchet by "feel" using the copper gaskets. I just checked it with the torque wrench starting at 35 pounds. 2 clicked at 37 - 38 pounds, the other two were 40 - 41 pounds. If anything I think I'll use the torque wrench at 40 pounds from now on for consistency. 4 pounds seems like a little too broad of a range to me.
