Horn
tinman7
Hi all, How do I wire a magnito horn for a 1917 Tourin and how does it mount on the fire wall? Horn button sits on the top of steering column.
Thanks
The correct bracket is available that one hole mounts to one of the steering column bolts - some mag. horns have 2 terminal & some 1 - I have a wiring diagram in the shop but you could probably find the wiring diagram on-line.
