helper springs
gmaynard
I need help in identifying a set of helper springs that came with a rear end I recently purchased. The rear end appears to be a 1937 thru 1941 rearend. It was being used under a 1936 Ford sedan. The rear bracket mounted to the shock bolt. The front was attached to the frame.
