Help with grease seal
firechief5215
I pulled my worm drive rear apart and I have found a felt grease seal that is damaged..This is a model a but it is a early 28 late February. It is the same as the tt rear Does anyone have a part number or know who may have 2 of these felt seal or even a replacement See attached pictures red arrow shows seal and other picture is my seal Thank You
If you have a good bearing house near you or a good tractor place, take a measurement
of the housing I.D. and the Axle O.D. and the thickness of the seal and see if they can
come up with a modern replacement seal.
Sometimes you get lucky. (and sometimes you find a seal)
Does it have a part number on it? Most seals are marked with a manufacture's number. If you find that a little sleuthing should allow you find them.
Got my seals today Thank you Which way does in go in. Does the open side of the seal go toward the pinion or away from the pinion
'OSO HANDY RESTORATIONS Thank you for the phone call . That was a great experience buying from you Fast shipping and great to talk to Thank you Billy
