Help with bearing #'s and sizes
4tford
Can someone help me find the sizes of these bearings. Thanks Bill Ford 48 6211 U4
Ford 09TS 6211 X
McQuay-Norris 2970 and 2970- .002
Federal Mogul 9805CA-20
Don't have a listing for 48-6211 or 09TS. 2970 are 39-42 rod bearings( std and .002 under) and FM 9805 are .020 under rod bearings for 39 - 42 engines.
CO9TS-6211-X equates to 39-45 full floating 3 3/16 bore with .002 undersize crank and .008 O S conrod bore.
Sorry, don't have a listing for 48-6211-U, however, C01TS-6211-U is for the Canadian locked in shell type bearings1939-45 3 1/16 bore.030 US/.008 OS.
C09TS-6211-U is for 1948-49 3 3/16 bore locked in bearings .030/.008 OS. Can we reasonably consider the 'U' suffix to denote .030/.008? Brian
On your Federal Mogul 9805CA-20 flatjack is correct on the data he gives but I would like to add that the CA means "bearing, steel back, copper- alloy lined".
