help identifying this part
If it didn't have the Ford script, I would think it looked like a very old plug from a lamp or toaster - every now and then my grandmother would insist on using an ancient toaster that would only plug into a specific receptical in her kitchen. Thank goodness it never burned down the farm...
Headlight resister????
No, the dimmer coil resister unit is completely different nore part of the horn switch. It looks to be Model T era. While the early Fordson tractor used the same switch as the car, they may have used a more permanent key that wouldn't have fallen out bouncing across the field as the coil box was out in the open.
If you study the Ford name you can see the F is definitely not that of the car maker's logo, the rest is considerably off as well. Perhaps this is from some aftermarket accessory or perhaps an appliance marketed by someone capitalizing on the Ford name.
