Hey guys,
I recently bought a mk1 escort that came fitted with a 1600cc Crossflow Engine.
All was going fine up until around a month ago when it developed a slight miss. Over the course of 1 hour it got worse and worse till the car was not drive able.
I replaced the points and that fixed the problem for about a week, until a slight miss occurred again, this time only getting bad enough to be annoying.
I went about replacing a few things, i replaced the spark plugs, spark plug leads, dizzy cap, condenser, and rotor. This fixed the problem for about a week until yet again it started missing!! I then replaced the coil and coil lead, this fixed the problem for 2 days and then once again the miss came back .
I have taken the carby off and had it all cleaned etc and nothing is blocked up there...
Tonight i cleaned the points , it drove well for about 2 minutes then the miss came back, got home and the points were black... could it be the condenser?
has anyone had similar problems? What else is there?
