Drilling out the stud can be problemmatic as the studs over time become work-hardened and will not easily drill out with conventional drills. At a minimum, if you elect to do it this way you should make a drill guide with the OD the diameter of the hole in the head and the ID of the drill you want to use. Or pull the head and use one of the commercially available drill guides.I have probed the hole on the head and it appears to be broken off flush with the block. I bought the truck sight unseen from a seller 1,500 miles away but the previous owner, an elderly gentleman who I do trust, told me a recent valve job had been done. That very well could be when the stud was broken.
I did notice the age but I'm too new a member to PM or email. Just hoping Dave in MN is still around. Thanks, Bruce
I didn't see it metioned but oversized head studs are available if you would rather go that route instead of inserts of any type.
@Dave in MN still posts. DurablePerformance.net[/QUOTE]
Thank you. I sent @Dave in MN an email at Durable Performance.
