This is a followup to a past post I had with the same problem.My headlights are blowing ( not both at the same time). I have installed a new alternator which during about a 30 minute drive and using a logging meter has an output of max.7.9 volts and min. of 5.6 volts.(measured on headlight wire). As suggested I ran a new ground wire to the lights from the frame and soldered them directly to the light socket. one light blew out during the drive. There is a small amount of discoloration in the bulb, so I don't think they're just vibrating and the filament breaking. Help !, bulbs aren't that expensive, but I've gone through 7 trying to find the problem. Thanks
