When the question was posted the other day I didn't have the time to respond. I have been doing this type of work for over 25 years, have installed hundreds of mechanical and computer operated hand and steering controls. Hand controls work thru twisting and application of leverage, a complete set of controls utilize one lever and will apply the gas and apply the brake. Various models do this by either twisting the handle or rotating the handle from approx. 9:00 to 7:00, while pushing the same handle towards the firewall to apply the brakes. Hand controls work well with with modern cars with power brakes requiring only a couple of inches of handle travel. With power brakes, one doesn't have to apply much effort, in an A with mech, brakes you need a great deal of travel and leverage to apply the brakes safely. This will make it impossible to to push the handle hard enough to stop the car. The gas control is not a problem, the clutch is, hand controls work only with gas and brake. How many of you out there could depress a Model A clutch with your hand, you would need a lever so long to give you the strength to depress the clutch 5 - 6 inches, you would have to leave the door off. And if you think about it, you normally have one hand on the wheel, you are coming to a turn, you have to down shift, turn the wheel, apply the gas, depress the clutch, shift the trans, turn on the turn signals all at the same time, you would need at least three arms and one would have to be quite a bit longer than the others. Yes it could be done with a custom built pneumatic system, I have done it with auto trans, but using 3 slave cylinders instead of two, a Model A could be adapted. This would require a 12 volt car, a special compressor, reserve storage tank and a control system that doesn't exist yet. You would need a area about 2'x11/2'x 2' to mount the supply componets. The cost would be quite high, somewhere between $3-$4000.00 if we were lucky, to do it with a computer (actually two) it may run as high as $35.000.00. My suggestion is have your family member or friend contact someone who is using hand controls in their A today with a auto trans, they can talk directly to a user and learn why the auto. trans is really the only way to go. Out here on the Left coast we have Art Moore, a FAST member, has three cars with controls and is building a fourth, I can put individuals in touch with him if you don't have his number. You can reach me at callcoy1@aol.com or 707-579-0338
Steve Ribeau
Steve Ribeau
