Tom Wesenberg Well-known member May 31, 2010 #1 Under the poster's name is REPORT and to the left of that is a green or blue dot. What is the significance of the dots and colors? Thanks
HoarseWhisperer Well-known member May 31, 2010 #2 Poster is Offline when blue, and green when Online?
TK in LA Well-known member May 31, 2010 #3 Green dot signifies your online right now. Blue means you're not. Put your cursor over the dot to find out.
Jim/GA Well-known member May 31, 2010 #5 There is a setting under your User Control Panel (User CP), in "Edit Options", where you can put a check mark next to "Use Invisible Mode". Then your dot becomes red and your online status is not indicated. Last edited: May 31, 2010
