generator question
steamgas
where is there a supplier for the wire that comes off of the brushes?this is a multie wire brided like a rope for flexibility.standard wire will not work because it will not let the brush float on the comentator.:confused:
I'm guessing your generator has been altered as generator brushes do not have wires attached. The type brushes you describe are used in the Model A starter however.
The powerhouse uses these type of brushes, so I am guessing he is working on one of them. Brushes for these can be hard to find and likely expensive when you do. Soldering the lead is his best option. Rod
I rebuilt a powerhouse a few years ago that had the braided wires secured to the brushes by some very tiny brass wood screws. It worked fine and looked so professional that I just assumed it was factory made that way.
