O oldgas Member Jan 9, 2024 #1 What did the 1956 Ford Victoria with a ford automatic transmission & a 292 2 barrel T pot Y-block have installed for best mileage performance rear diff gear ratio? Thank you for your time. Oldgas
KULTULZ Well-known member Jan 10, 2024 #2 See if the attached ILL shows large enough to read - Attachments DIF - Gear Ratios - 1949-56 FORD.jpg 109.4 KB · Views: 53
paul2748 Well-known member Jan 10, 2024 #3 56 sedans with Fordo had a 3.22 rear end as standard and a 3.55 as optional
