JayJay
I know this question has been debated, but...
I'm installing a Mitchell overdrive and Mitchell requires 85/140 petroleum-based (not synthetic) gear lube. I currently use 600W (from the vendors, don't recall where I got mine) in my transmission, differential and steering box. It would be convenient, but by no means deal-breaker, at the next fluid change (coming up before I head to Ruidoso in June for the MAFCA convention) to switch everything to 85-140 so I would need to carry only one gear lube. I have no particular complaints about how things work with the 600W, other than the ****** does shift very stiff and grinds a lot when cold.
Does anyone see any huge negatives to this plan?
I have no idea what fluid is in the shocks. 85-140 for there too, or is that too thick?
Thanks.
Thanks.
