Steve_Mack_CT
Curious if anyone else with a similar set up finds that a slightly richer mix to be optimal. I have a fresh engine (maybe 5 hours on it so far). Snyder's 5.5 head, B cam grind and 0.100 overbore. Runs great with exception of stalling twice on deceleration. GAV essentially closed as I would ordinarily run once up to temp. Before looking at the float I am wondering if the issue could be as simple as running too lean. I am unsure if these minor mods would call for a richer mix but have also read issue could be as simple as a lean mixture.
I don't seem to have an issue on corners which I know could be flooding - tough to tell for sure as it happened quick but felt more like starvation vs flooding. I know some variables at play here but am curious what others experience has been woth a similarset up.
Thanks, Steve.
Thanks, Steve.
