J jimtims Junior Member Aug 1, 2014 #1 I have a 47 ford pickup with a flathead V8. I installed a carter electric fuel pump. Do I need a fuel regulator to reduce the pressure from 6 psi. It seems to run fine with no regulator. I live at 10,000 ft if that makes any difference. Jim
Lanny Well-known member Aug 15, 2014 #2 This section is for "Questions to the the Editor". You should post your questions in "General Discussion" in the Early V/8 section. good luck,,, .
