Lenny Bruce
Good evening. Does anyone have directions on how to Time a Model A engine when installing the modern style FSI Distributor?
I don't see the timing instructions posted online, but the best thing to do is to call Shawn Buller at FSI. He provided all the info I needed about my FSI dist on a car I had purchased and in fact, diagnosed the problem I was having (a heat-failing coil) over the phone.
Better customer support simply doesn't exist.
I haven't seen inside the FSI but I'd wager the cam is fixed on the shaft and you move the body of the distributor rather than being able to reposition the cam on the shaft.Can the NuRex wrench be used?
