front wheel bearings again
thom
Been discussed (and probably cussed) before I know. I found that my car had a ball inner and a tapered outer bearing on the passenger side. The outer was not the correct threaded bearing for a T. The drivers side had inner and outer tapered bearings but no inner race in the hub and the wrong, non-threaded outer bearing. I don't believe the car was driven that way. I don't have an inner race on hand and I hope that the hub is not damaged and that a race will fit in the hub as it should.
