I am rebuilding the front axle and note that both the wishbone and steering arm balls are worn badly. A previous owner installed a spring loaded connection (ampco I think). Do I replace the balls or shim? I note that Langs does not sell replacement wishbone and steering arm balls but does sell the shim kit. Macs has a new wishbone kit where you cut off the old and weld on a new one. Does, anybody have experience cutting the old one off and welding the new one on - correctly. Seems like if you were off a little bit, you could really mess up the front end geometrics.
Langs has a NOS wishbone but it is a little pricey. The front end booklet says the wishbone ball should be withing .020 of round. I bet mine is egg shaped .250!
Langs also has a replacement steering arm. Anybody have experience using one of these? I am kind of partial to the Ford script parts that are on the car.
How about building up the parts with weld and then filing/gringing?
Thoughts??
Thoughts??
