Earle
I've had the front brake drums off and on dozens of times in 25 years and was just informed that I have been doing it wrong! (by my very-trusted mechanic - who shall remain nameless - to protect the innocent). Now I am the proud recipient of "authoritative" but conflicting advice on how tight to make the spindle nut before installing the cotter pin:
Technique #1: (per various owners, and "A" restoration books, etc.) - "Finger-tighten" the spindle nut against the bearing retainer washer while spinning the brake drum to insure the bearings are well in place and most of the grease is squeezed out from the roller-race contact surfaces. Then back the nut off to the next nearest slot in the nut. Install the cotter pin. After the wheel is istalled, pull in and out at the top of the wheel. No looseness or a VERY SLIGHT amount of looseness is OK. This insures that some grease can circulate throught the bearing rolling surfaces while running, keeping the bearing cool and not over stressed. "Any tighter on the nut will cause accelerated bearing failure."
Technique #2: (recently per a "very-trusted & experienced 'A' mechanic") - Same procedure as #1 EXCEPT after the nut is "finger-tight", turn the nut TIGHTER to the next slot in the nut using a wrench if necessary. Then install the cotter pin. "The bearings must be preloaded. ANY looseness at all will cause accelerated bearing failure." There NO looseness in the wheel, of course, after it's installed.
HELP! what do you experienced Barners do? I have always used Technique #1 and never had a bearing problem. I DON'T like the idea of having the bearings clamped up tight and beyond. Intuition, mechanical sense, and engineering experience tells me that this forces all the lube out from the roller-race running surfaces, causes a hot-runnung bearing and increases fatigue loading and brinelling-failure of the race.
Since there may be more time-tested Model A "art" than science here, I'd like to hear how you guys approach this "simple" task!
Getting this "simple" task wrong could lead to bearing failure which could mean loss of control on the road. This critical task should probably get more attention and discussion than it typically does.
Earle
Earle
