Fresh air duct flapper re[placement
1930artdeco
Hello All,
I am finally putting the dash back in and it is time to rebuild the fresh air ventilators. How do i get the flapper part out of the housing without separating it into pieces (I don't really want to do this). How you all done this?
Mike
Take the duct out of the fender apron and turn it upside down on a pair of lumber big enough to allow the crank/shaft to come out of the bottom.
Take a hammer and hammer the bottom of the shaft till it loosens, then pull the shaft out the rest of the way. Reach in and pull out the damper laying inside the duct.
You'll need to drill out the welds that hold the two metal damper sides together in order to replace the rubber. Most of the repro parts suppliers sell the rubber replacements.
Be careful putting the shaft back in t6hat you dont have the crank facing in the opposite direction it was originally.
Update: I was able to ‘flatten’ the ducts just a smidge by laying on them. Which in turn allows you to pop and then pull the flapper out of the housing. I pulled all of the staples and replaced them with new T50 staples. Then reinstalled the flapper-good as new!
Thank you all for the tips.
