The method that was published a few years ago was to chain each end of the frame down to an anchor in 10 inches of concrete, then jack up the low spot with a 10 ton bottle jack. The instructions showed a block of wood between the jack and the frame. The frame was chained down at the shock locations. I cannot remember the details of how the chain was mounted to the frame, but maybe using the bolt holes for the shocks.
An alternative would be to use a stout I beam or H beam to chain the frame down to and to support the base of the jack.
Are you sure you have sag? I thought I had a sagged frame but it turned out to be flattened rubber pads between the frame and body. The normally 1/4 inch thick pads were flattened to paper thin in places, and brittle. The pads can be added by converting the holes to U shaped and sliding them between the frame and body at the bolts. Of course you have to loosen all the bolts and slightly raise the body up. I had to add two pads in places to get my doors to fit perfectly. I also had to replace all the bolts because the body had never been off the frame and all the bolts were in poor shape.
