Four Way Flasher Switch & More 1958-66
barnstuf
Cape Cod
MA
Price
in ad
I am offering two related but different 4 way flasher switches as listed below. Prices PLUS POSTAGE.
1/ Four way flasher switch only, Ford part number C1TB-15583-B, made by Signal Stat and operates on a push/pull basis with a red knob, with five wires (2 green, one blue, one yellow, one white). I have switch only, no instructions and the Ford part number indicates it is for 1961 and very likely for several later years. It has a threaded mount for dash or with bracket under dash. $15.00.
2/ Four way flasher switch kit for 1958-1966 cars of many makes, including Ford, that have factory installed turn signals. It is a switch with wires about 18 inches long. It is a Signal Stat kit to use as a replacement when the original switch is not functional. It has four red wires, plus one brown one with fuse. It is dash or under dash mount, push/pull operation with the knob red and probably illuminated. Has brief installation instructions, $20.00.
