Fordor Garnish Molding
kenparker
Van
TX
Price
$300
Original Garnish molding for 1930 or 31 Fordor Sedan. Two long pieces for front door. Two next shorter pieces for rear door. Short piece at top for rear quarter window. Piece with no paint ?????? For further info email kenparker0703@aol.com or private message.
For Further Reference:
1931 Murray Slant Window Garnish Moldings
Front Door Window Frame ------- 25 1/2"
Front Door Trim Under Frame -- ?
Rear Door Window Frame -------- 25 1/4"
Rear Door Trim --------------- 24 15/16"
Rear Quarter Window Frame ----- 16 1/8"
Rear Quarter Trim ------------- 15 13/16"
Unfortunately I don't have the front door trims -- Since the other trims are 5/16" shorter than the corresponding window frames. one might assume that the front door trim should be 25 3/16" -- OR -- Ford might have used the same trim for front and rear doors since there is only 1/4" difference between the frames
Doug
