Ford canada early v8
Fuimus
Help Please!
For re-registration in South Africa, I need to prove that the Serial Number on my 1935 Ford V8 Special, coach built by Jensen Motors in the UK, is genuine.
There was a Production Schedule I previously accessed from this Forum on the website "wnyrg", which no longer seems to be active.
My Licensing Authority requires either a Manufacturers Certificate of Origin, a Letter from Ford of Canada, or an official Production Schedule which clearly shows that my Serial Number is genuine.
I just cannot find this schedule anywhere online.
Thank You
Brian:)
Can you post several of the letters and digits from the serial number that should be stamped on the frame above the steering box. Such as C18-1234567
Found this on the site you were probably looking for:
https://www.wnyrg3.org/CANADIAN-SERIAL-S
Hope this helps, Good Luck.
576744
