Ford 8BA engine for sale
reed1944
St Petersburg
Florida
Price
$2,500
Ford flathead 8 BA block that has been magna fluxed. Block will need boring. 4" Mercury crank turned .020 mains and .030 rods, New Johnson style lifters, cam bearings, valve guides, keepers, valves, springs, retainers, valve guides, valve guide retainers, valve guide o rings, rear main seal retainer, 8 connecting rods, 2 Bob Drake water pumps, aluminum timing cover, Edelbrock finned aluminum heads that have been surfaced, new timing gear, lower crank pulley, oil pan with dip stick, oil pump with pick up, rear cam gear and cover, crank oil slinger, distributor hold down bracket, original oil filter and flywheel. All of the hard to find parts are here. Save yourself a lot of time and money!
What will be needed are new pistons, rings, valve seats, cam of your choice and an engine gasket kit.
Call or text 727 420 8854
