I have a 56 tbird that has a air cooled Fordomatic. The flywheel is a 1/4 inch thick plate with two flexible flanges ( three holes in each) attached to the outside edge of the flex plate. They set opposite of each other on the perimeter at 12:00 and 6:00. the plate attaches to the crank shaft with three 1/2 bolts(fine thread) and the manual says they should be torqued to 75-80 lbs. My question is this: Should these bolts have lock washers? The used bolts that I have also had lock washers with them but with the lock washers under the head, the threads of the bolts do not fully extend thru the crankshaft plate. With the manual calling for 75-80 lbs torque, this seems a little extreme when only approx 7/16 inch of the bolt's threads are engage. Any advise welcome!!!
