firing order
prairieboy
which of these is the correct firing order for a 292 Y block engine
A 15486372
B 15426378
C 13726548
I am not sure but I think the first one is the correct one yet when searched on google the second one is the one listed for 292 v8 to me that firing order is for FE engines not Y block engines:confused::confused: I will contact a old mechanic friend to see if he knows which is the right one
Chain’s right, here it is on the intake (stolen picture). Remember #1 is pass front, 5 is driver front.
thanks for all the help the intake on my 57 292 does not have a firing order stamped on it hence the reason for asking I thought that A was the correct on as I have had several fords with fe engines and knew they were different but when searching on google every y block firing order came up as the fe order once again thanks to all who replied
