Paul,
The angle adaptor Ford offers is for engines that have the filter mount cast in the block, whereas the FE uses a separate mount that accepts the filter. I learned it's possible to use the angle adaptor with the FE mount, but would rather use just one mount.
Bob 37,
I will remote the filter if I have to, but would rather use an existing factory piece if available
Thanks for you comments.
