the-stig
[FONT="]Engine[/FONT]
[FONT="]MOTOR SWAPS
5.0 EFI swap [/FONT][FONT="]http://www.midnightdsigns.com/Mustang/Engine.htm[/FONT][FONT="]
Small Block Ford, AKA SBF (260/289/302/351W)
FE Ford: [/FONT][FONT="]http://www.jalopyjournal.com/forum/threads/ford-fairlane-500-1957-engine-swap-v6-to-fe390.953789/[/FONT][FONT="]
Notes - 260/289/302 engines are your best bet for an easy fit. 351W engines will fit, however they are slightly wider at the heads, which may cause clearance issues (such as headers, steering box, etc). Head and block info:
[/FONT][FONT="]http://diyford.com/ford-cylinder-heads-valvetrain-interchange-small-block/[/FONT][FONT="]
Clearance between the water pump pulley and radiator can be tight, especially when using the v-belt 70-78 Windsor pump (5.700" hub to base). For v-belt applications, a short water pump (5.440" hub to base, pass side inlet, 65-73 SBF and some later tucks) should be used. A Ford Motorsport M-8501-E351S can also be used for even more clearance. The FMS short pump will require custom pulleys, available from [/FONT][FONT="]CVS Rac[/FONT][FONT="]ing
Depending on the thickness of the radiator used, and the water pump used, an electric cooling fan may be required
Motor/Trans Mounts ('54+)
[/FONT][FONT="]- 1986 Lincoln MKII/Thunderbird/Mustang 5.0, Anchor part # 2725 (L) and 2726 (R)[/FONT][FONT="]
- [/FONT][FONT="]1963 Falcon 260 mounts, Anchor # 2220 (L) and 2221 (R)[/FONT][FONT="] - In my experience, these are a better option if you are having firewall/trans tunnel clearance issues, as they position the engine lower and further forward. These are the mounts I used with my '54 302/T5 swap because I was running into firewall/throttle linkage clearance issues with the Lincoln mounts.
- [/FONT][FONT="]Prothane 6-501-BL - Prothane Motor & Transmission Mounts[/FONT][FONT="] - The matching mount for C4 or AOD is this: [/FONT][FONT="]http://www.jegs.com/i/Prothane/311/6-1605/10002/-1?parentProductId=762286[/FONT][FONT="]
- T5 transmission mounts - [/FONT][FONT="]Energy Suspension 3-1109G(need link)[/FONT][FONT="]. I ended up using a [/FONT][FONT="]universal trans mount kit (Prothane#311-6-501-BL)[/FONT][FONT="] on the stock crossmember for my '54 w/302/T5.
- Butch's Cool Stuff also offers a bolt-on engine/trans mount kit... [/FONT][FONT="]SBF in a 17" 52/53[/FONT][FONT="], [/FONT][FONT="]SBF in a 15" 52/53[/FONT][FONT="], [/FONT][FONT="]SBC in a 52/53[/FONT][FONT="], [/FONT][FONT="]54/56 V8[/FONT][FONT="], [/FONT][FONT="]54/56 I6[/FONT][FONT="], and [/FONT][FONT="]others[/FONT][FONT="]. They also offer a 5% discount for group members or a 10% discount for HAMB alliance members.
Y-Block Swap in a 52-53 Ford Scroll down to post #21 [/FONT][FONT="]http://www.jalopyjournal.com/forum/threads/anybody-got-a-y-block-in-a-shoebox.177373/[/FONT][FONT="]
Notes
- [/FONT][FONT="]Here is an album[/FONT][FONT="] with good photos of the minor modifications that need to be made to the motor mount pads on the factory crossmember for '54+ cars when using the factory style SFB mounts above.
- Polyurethane mounts are less prone to separation than the Anchor parts that are now made in India/China.
- Above applications are for 260/289/302 swaps. For 351W swaps, clearance may be an issue. See [/FONT][FONT="]Rockabillykat666's thread part 1[/FONT][FONT="], and [/FONT][FONT="]part 2[/FONT][FONT="] regarding 351W fitment experiences and ideas.
1952-54 Ford gas tanks These always seem hard to get and cost more,Good News! [/FONT][FONT="]http://www.jalopyjournal.com/forum/threads/1955-gas-tank-in-a-54.985110/[/FONT][FONT="]
Oil Pan
- '52 and '53 Fords - dual sump oil pan from a fox-body Mustang.
- '54-'56 Fords - front sump oil pan should be used (use Melling 68-S pickup).[/FONT]
[FONT="]Help for those with the 223 Six motors: [/FONT][FONT="]http://fordsix.com/forum/viewforum.php?f=18[/FONT][FONT="]
[/FONT][FONT="]A great resource for detailed specs and info for almost any car made after 1945.[/FONT]
[FONT="]More about Ford Engine swaps: [/FONT][FONT="]http://www.jalopyjournal.com/forum/...yet-incomplete-ford-v8-swappers-guide.199198/[/FONT]
[FONT="]If you are thinking of an engine swap here is some good info you may want to save [/FONT][FONT="]http://www.carnut.com/specs/fengdim.html[/FONT][FONT="] However one part that needs correction is the SBF which like SBC's also had a short and long water pump the short pump and balancer from 1965-69 will shorten an SBF overall by 2 1/2"[/FONT]
[FONT="]For the front sump pans I recommend [/FONT][FONT="]http://kmjperformance.com/sbf-ford-...ark-blue-small-block-windsor-260-289-5-0.html[/FONT][FONT="] good prices! the pickup is a Melling part# 68-S available at Autozone for $16.49 always change the oil pump drive shaft part# IS-68 $11.99 or if you use a HP pump get the H.D. shaft available from A.R.P.[/FONT]
[FONT="]Thinking about doing an engine swap? Handy chart right here: [/FONT][FONT="]http://www.carnut.com/specs/engdim.html[/FONT][FONT="] This chart lists the weight of most engines [/FONT][FONT="]http://www.gomog.com/allmorgan/engineweights2.html[/FONT][FONT="] Guide to Ford engine block codes [/FONT][FONT="]https://www.enginelabs.com/engine-tech/a-guide-to-ford-v8-engine-block-casting-numbers-1952-1996/[/FONT][FONT="] (Of course Ford in a Ford is a good thing)[/FONT]
[FONT="]Putting a Y-block in a 1949-53 Ford car lots of pictures and text: [/FONT][FONT="]http://www.jalopyjournal.com/forum/showthread.php?t=177373&page=2[/FONT][FONT="] Here is another take to doing it. [/FONT][FONT="]http://www.jalopyjournal.com/forum/threads/1950-shoe-box-y-block-install.1051398/[/FONT]
[FONT="]I have used these folks for Carburetor parts and recommend them to deal with: [/FONT][FONT="]http://allcarbs.com/salelist.php?stt=30[/FONT]
[FONT="]Another source for the motor mounts we use in a 302-351 swap in 54-59 cars. [/FONT][FONT="]http://www.latemodelrestoration.com...eo&utm_medium=retargeting&utm_campaign=criteo[/FONT]
[FONT="]Goldmine of "Tips and Tricks" pick a topic off the sidebar and enjoy:[/FONT][FONT="]http://www.how-to-build-hotrods.com/engine-swap.html[/FONT]
[FONT="]Little bit of info on port matching SBF heads: [/FONT][FONT="]http://www.mustangandfords.com/how-to/engine/mufp-0605-ford-mustang-cylinder-head-porting[/FONT]
[FONT="]Ford engine dimensions chart: [/FONT][FONT="]http://www.bing.com/images/search?q=Ford+302+Engine+Dimensions&FORM=RESTAB[/FONT]
[FONT="]Here is a 302 tear down for the SBF crowd:[/FONT]
[FONT="]https://youtu.be/ssJ7-sCo_rg[/FONT]
[FONT="]https://youtu.be/AnU7f223BJo[/FONT]
[FONT="]https://youtu.be/uyuWItoEFYE[/FONT]
[FONT="] Picking a 289-302 Cam info: [/FONT][FONT="]http://fordmustangcar.com/repair-and-manual/hydraulic-cams-small-block-ford[/FONT]
[FONT="]ENGINE SWAP INFO and more
[/FONT][FONT="]http://www.onallcylinders.com/2013/01/10/engine-dimensions-for-popular-swaps/[/FONT]
[FONT="]Here are some pictures of a 302 swap into a 1953 Ford Customline using the mounting kit from Butch's: [/FONT][FONT="]http://www.butchscoolstuff.com/52-53-ford-car-15-sb-ford-eng-trans-mount-kit-2501cpb/[/FONT][FONT="] The headers used are the HEDMAN 88400's showing the steering box clearance. The mini-starter is from DB Electrical.[/FONT]
[FONT="]Guide to Ford ID Codes: [/FONT][FONT="]http://www.mustangtek.com/FordDateDecoding.html[/FONT]
[FONT="]Big Block Mopar swap with pictures [/FONT][FONT="]https://www.jalopyjournal.com/forum/threads/from-across-the-pond.1061751/#post-12051152[/FONT]
[FONT="]Here are some pictures of a 302 swap into a 1953 Ford Customline using the mounting kit from Butch's: http://www.butchscoolstuff.com/52-53-ford-car-15-sb-ford-eng-trans-mount-kit-2501cpb/ The headers used are the HEDMAN 88400's showing the steering box clearance. The mini-starter is from DB Electrical. 6 pictures[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]390 swap in a '54 2pictures[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]Tuning Tech [/FONT][FONT="]https://www.racingjunk.com/news/2019/03/19/using-engine-vacuum-to-diagnose-performance-issues/[/FONT]
[FONT="]Starting an engine that has sat a long time ? [/FONT][FONT="]https://www.jalopyjournal.com/forum/threads/good-article.1145917/[/FONT]
[FONT="]Sometimes guys get the idea to use something different when doing an engine swap and exhaust might be an issue,here are some Tech Tips: [/FONT][FONT="]https://www.speedwaymotors.com/the-...920&utm_medium=email&utm_content=toolbox-hero[/FONT]
[FONT="]MOTOR SWAPS
Notes
Oil Pan
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[FONT="]
[FONT="]
[FONT="]
[FONT="]
[FONT="]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[/FONT]
[FONT="]
[FONT="]
