Today, I went to start my coupe after replacing the generator. Normally The engine fires up after a couple seconds but today it would fire up but crap out after a few seconds. After several attempts with the same result, I did some trouble shooting, finding 6.3 volts at every point along the way including the BAT side of the cutout. The timing was tested and found to be spot on.
While turning the ignition off and on during the troubleshooting I observed the ammeter jump a bit to the discharge side, as normal. After not finding anything amiss I attempted to start the engine but noticed that ammeter now failed to jump a bit as normal when turning on the key. Turning on the lights failed to move the ammeter needle at all.
I would appreciate any thoughts about this issue. Thanks much!
