edelbrock carb
len
I have a 56 ford with a 292 standard trans. Am considering a Edelbrock carb. Any sugestions as to size and installation. It has a four barrel on it now with a ford tpot carb.
An Edelbrock 500 CFM with electric choke works great, but wont bolt to your intake. There may be an adapter available, or you can use a 57 up or Blue Thunder intake. Always mount an Edelbrock on an insulator at least 1/2 inch. One thing to remember, the distributor design changed in 57. If you change the carburetor on a 56 or older Y block, to make it run its best, you MUST change the distributor to a 57 or newer.
