Early V8 distributors
mcgarrett
Corsicana,
Texas
Price
In ad
Distributors for Flathead V8 Fords:
(*Each distributor has been completely disassembled and thoroughly cleaned and inspected for damage.
Good or new ignition points installed, correctly gapped and timing properly set using K.R. Wilson timing fixture.)
One 1939-1941 complete distributor - good coil, rotor, points, vacuum brake piston and spring and caps (no condenser) $175.00 (SOLD)
One 1939-1941 distributor body with rotor and points, vacuum brake piston and spring (no condenser) $85.00
One late 1936 distributor body with rotor and points, vacuum piston and spring (no condenser) $75.00
What you see in the photos is what you are buying. Call Mike for more information: 214-287-6079 if I don't pick up, leave message. I don't do Paypal. Personal check or Postal Money Order.
