petehoovie
These things? They look like holes.
I will get it up from hottank today and make a puller and then I see whats behind.
I think its OD 3.5/16”.
If so, then you'd be in great shape if the underlying material is good. You can get pistons from Ross at any size. The key is finding good quality rings FIRST - then order the pistons to match.
I has took out a sleeve and bore is nice behind on this cylinder anyway and I can't say but it feels like this is a factory sleeved block and it will be no suprice behind, but it's a seat for the sleeve ( se picture ) and diameter on that is 3.368" and deepth is 0.10".
The bore is pretty round ( 0.001" oval ) so bore is 3.2693".
Std plus 1/8" is 3.3125".
So get there is + 0.062".
Will remove rest of the sleeves.
If no issues, what is the best do here in final bore vs the 'seat' ?
Block is/was pretty rusty inside.
What to use 1.6 or 1.2 or 1 mm rings.
I will hone with TQ.
TS has almost all rings in mm but I has never bought this diameters.
So first visual, then hone see where it leads then check with TS snd then ask Ross.
They will do what I ask.
