T tommyleea Senior Member Apr 12, 2020 #1 55 F100..272..Would the draft tube be the same for a front sump and rear sump oil pan? My question would be about the return tube. Thanks
KULTULZ Well-known member Apr 12, 2020 #2 Yes, the same as both pan styles would take the same draft system as the opening is on the LF block skirt. Is yours like this?
T tommyleea Senior Member Apr 12, 2020 #3 KULTULZ said: Yes, the same as both pan styles would take the same draft system as the opening is on the LF block skirt. Is yours like this? Click to expand... Yes, left front..I was just thinking maybe the return tube was different, because of the depth of the pan..front sump vs rear sump. Thanks
