Double post please remove
Re: 28-29 cowl post stanchions inside bracket
You didn’t mention the model of your car. The only one I’m aware of making reproduction parts is Brookville but they only make them for open cars, e.g., roadsters and roadster pickups. Not sure if that part would fit other cars. You might have to check out the swap meets or online.
David Serrano
Those are on all the 28/29 Phaetons and open cab pickups as well. Brookville manufactures all the sheet metal for model A roadsters and open cab pickups. Phaetons only share the cowl & front doors on four door types.
Sorry 28-29 Roadster ,my cowl post is perfect just missing that inside bracket,and when I click on the Brookville picture it just shows the whole post ,but looking at it it doesn't even show the part I need attached to the post? Are they just using nuts ?
I would call Brookville and see if they would supply just the part you need. May not be in the catalogue, but they have to make them so maybe.......
Thanks everyone. Definitely appreciate your help and time , I'm going to follow up with vintageford and see if I can get a photo
The model A parts sources stock a lot of Brookville pieces but finding them in their respective search systems can be a challenge. The paper catalogs were easier to use. Nomenclature for some parts differs and sometimes the parts aren't pared well with associated assemblies for search attempts. It can make for a long search with no good final outcome sometimes.
