door hinges
elwood
hey guys, the hinges on my 29 tudor sedan are loose, there rivited on, and i was needing to know how to tighten the rivite up ?
wondering if i mig the insides of the rivits if they will pull tight ?
thanks
You need a cleave aand hamer you set the cleave on one side and take a hamer with and pownd it and it will tigtin it back up 1 cleace is a peace of meatal with a rivit head szed indent in it set that on the out side and hamer from the inside.
I gess your right but if you take a pry bar with a cleave cut down to fit between the outer skin and the iner plate thenj weld the cleave to the pry bar you can get in up there settle it on the head and and be able to use leverage to keep it still then just hammer the outsde with a second cleave and hamer.
