Dome Light
zk1976
New member
For a 1930 Model A Fordor Sedan, is there a video or actual picture showing dome light routing from the ceiling to the driver-side stanchion. Thanks.
Zaki
Zaki
You might get a better response if you specified what year and type of car you are talking about.
Zaki
The dome light wire routing for the Slant window Sedans (160B & C and 190A (Victoria) ran from the Terminal Box, up the left (driver's) windshield post to a screw in the header above the headliner. From the screw a new wire ran to the light switch in the passenger side front door pillar. From the switch the wire ran to the dome light.
See page 2-15 of the revised 2011 Restoration Guidelines.
Zaki
Thank you Bill. I was wondering about how the wire entered the left stanchion from the screw without interfering with the backer plate that supports the windshield arm. I see a big cutout in the middle of the stanchion. However, the wire will get squeezed, if I wire on the outside of the stanchion until it reaches that cutout, when I put the backer plate back. thanks.
Zaki
