Where does one get a .012" fiber washer?
I don't recommend the fiber washer use, it's not going to last long....
I have found that the fiber washer is too thick in most distributors I have rebuilt.
I was debating about chucking up the collar in a lathe and "fine tune" it a bit. I may go that route.
Do you drill the collar/shaft out for a roll pin? It seems to me from the little bit I monkeyed with it the holes were different sizes, side to side. i.e. the pin only went in one way...
