yes BUT you will have to overcome distance.32-41 has a cam with a extended nose to reach shorter 32-41 3 bolt distributor .The 42-48 2 bolt dist is longer and will not touch the later cover as dist will be against cam .Easiest way is to use 3 bolt cover with a "bolt on" 3 to 2 adapter which is right thickness to fit cam & dist.
