Something isn't adding up with the figures you have given. Assuming you have the stock size rear tires and the ratio is 3.30, the RPM at 60 should be about 2428 according to this RPM calculator.
https://spicerparts.com/calculators/engine-rpm-calculator.
The 3.3 ratio would have been in an automatic car, but things get changed over the years.
I don't think there is a numerically lower rear ratio for the '55 rear end. Maybe something aftermarket, I don't know.
