I have a 37 Tudor Sedan with a good sized dent in the center of the grille.. What is the best way to remove it?? I bought another to replace it, and it turns out to be a knock off.. Just won't fit right.. Thanks.. Al
If its not kinked, try some wide straps or a leather belt and work each grill bar a little at a time til you get them all straight and even. If they are kinked, you'll probably have to do some cutting, straightening and welding.
