Current draw for stock A horn
pdora
My horn doesn't work and I am preparing to troubleshoot. The wiring to the horn by way of the horn button checks out.
For logistical reasons I need to work on the horn in my workshop and not near the car. This means I need a source of 6-volt power for testing.
I have a 1-amp, 6-volt battery charger. Is this sufficient to power the horn, or must I look for another source? I really don't feel like removing the car battery and hauling it inside.
Thanks.
One amp is not enough. Tom Wesenberg will no doubt post a correct figure, but it is several amps.
Note that the button provides ground to one terminal of the horn, and the other terminal should be hot full time--assuming you have an original horn. A VOM and a jumper will help you isolate the problem to power, ground, or the horn itself before you remove it from the car.
Joe
Thanks.
I have isolated the problem to the horn itself.
BTW - does polarity matter? I would guess not since it does not use permanent magnets.
My horn wouldn't stop honking and I discovered that one brush holder was missing the insulating washer between it and the frame.
Every horn I've checked has drawn 5 amps when properly tuned and running. It will take a bit more to start the horn armature spinning from a dead stop. A 6 amp battery charger might be OK. If not,you can back off the adjust screw to get the armature spinning, then tighten the screw to the correct tone.
Just carry a couple wires and horn to the car if you don't want to remove the battery. A 10 amp charger should be plenty good for testing the horn.
My horn wont work at idle speed ,but when I speed up the engine it will sound fairly good . Just rewired one side of the field coil.Wonder if a Horn relay will help ,its 6 volts .
