I have '58 with the 332CID, 4bbl V8. The shop manual says to use 20W oil when the outside temp is above 32 degrees F. Since I live in the deep South, that temp describes most days, so no problem. I've also been told, that because of our long hot summers, I should use 20W50 to better withstand our 100 plus degree days, as well as defend against any minor gas leakage from the carb should that occurr. Does this make sense? Will the 20W50 have any effect on oil pressure?
And one more question, is a 20W50 oil basically a 20W oil with viscosity enhancers for higher temps, or is it a 50W oil with viscosity reducers for lower temps? Thanks in advance.
Finboy
Finboy
